Binaural Brainwave Generator
Discussion in 'Electronic Design' started by scott93727g, Nov 15, 2008.
  1. scott93727g
    scott93727g Guest
    BrainStimPro Binaural Brainwave Generator is a Professional Medical
    Brainwave Tuning tool for medical personal. With adjustable freq, base
    frequency, modulation, duration, 8 programmable mask/background noises
    (White, Pink, Surf, Rain, etc) 16 programmable color strobe sets
    (foreground/background), 4 waveforms (Sine, Square, Saw, Triangle, 12
    Programmable Ramp and Sweep Frequency functions, audio to visual pulse
    ratio adjust and 24 programmable freq. buttons. In short the software
    has well over 300 different options.
    The Audio tone generation for binaural brainwave synchronization uses
    latest directX sound system oscillators, has 4 different waveforms and
    20 brainwave frequency bands with 2X and .5X functions and up/down
    1/5HZ buttons plus manual entry frequencies for a unlimited frequency
    spectrum for brain wave driving from Delta to Ultra Gamma, (1 to well
    over 15600HZ). Adjustable base frequency (10HZ to 15600HZ), phase
    modulation 0% to 50% channel reversible, 8 masking noise Options,
    (Unlimited with different file names) , Mixer controls, presets and
    programmable frequency controls. Also has a programmable color strobe
    (Stim / Background) stimulation section frequency driven with 16
    independent different color pairs and sound to light ratio adjustment
    with 1/3 of full screen usage.
    A new just released upgraded version now has 24 programmable frequency
    buttons to store your favorite frequencies and comes pretuned to four
    of the major Schumann's resonance frequencies to enhance amplification
    of the naturally occurring peak frequencies of the brain. By using
    base frequencies that are an even 10X the frequency of the Schumann's
    resonance, further enhancement of driving efficiency is attained.(see
    Below).
    As of Ver 2.2 (this one is ver 4.0) all functions are now available
    from the pull down menus as well, (Well over 130), added better
    durational display information, more precise timer controls, and
    better color choice information. And rewrote the user manual. Added
    full Screen strobe functions, 3 X the programmable buttons (now 24 not
    8), By clicking on the PrgSet button, the buttons marked A-H change
    from A-H to I to P to Q to X and back to A to H with separate Prg Set
    buttons (Also change name), (to store frequencies entered in the text
    boxes), and much more. As of Ver. 3.2 4 buttons give you instant
    access to the windows Wave recorder, Media Player, Mixer Console plus
    DXDiag for studio recording and mixing of the binaural sounds. Another
    first as of ver. 3.5 : you can now program 12 different custom sweep
    freq scans from low to high or high to low with different binaural and
    base frequencies with 1 to 60 min sweep times per freq. plus custom
    settingas well as upper and lower frequency limits.
    As of Ver 4.0 the user now has 10 trigger Conditions and 10
    Programmable Events for a total of 100 different event trigger
    combinations to control other programs, events, stimuli, etc. Useful
    for different audio functions, screen information, different visual
    stimulis, Pos rewards, slide shows or presentations. Or for therpy
    with images with psychophisological impact on the challenging
    situations in individuals lives, etc..
    A visual section for on screen photolytic Stimulation or Relaxation
    driving with adjustable colors and sound frequencies for precise
    sound / color frequency octave matching (sound freq vs color freq).
    Now has 16 programmable color sets (foreground and background). As
    well as a sound to color harmonic adjuster for Video/Sound offset
    (flash rate of stobe vs sound freq rate ), for audio to video driving
    lobe synchronization freq differents. (Since Occipital Resolution freq
    (Sample rate) is different then auditorial lobe freq resolution). The
    above simply stated is that different colors for different frequencies
    and flash ratios for audio and visual lobe stimulation can be
    adjusted. Use with headphones for enhanced meditation or for enhancing
    better brain function (higher frequencies).Will run on any windows
    version.
    http://www.binaural.info/index.htm
    http://groups.yahoo.com/group/BinauralTones/
