I
ivanatora
Hello,
I'm searching for an IC which can convert binary input to BCD code.
I have a TC77 temperature sensor, which provides data to 8-bit shift
register, and finally I have 8 bits in complementary code for negative
temperatures, and straight code for positive temperatures. Let's put
aside the negative numbers for now and concentrate on simple binary to
BCD converter. I want to put that reading on a 7-segment indication
via 7447 driver.
So long for now I've found in Google ICL74185 as binary to BCD
convertor, but I will need 2 or 3 hooked together for converting 8-bit
number. Also I can't find that IC anywhere on our stores and it seems
it is not in production anymore.
The other question is - is there a IC for converting the complimentary
code into straight code?
I don't want to use microcontrollers.
Regards, Ivan.
via 7447 driver.
Regards, Ivan.
