Hi all,
I'm currently hacking an old arcade machine to work with an Arduino. It has some 24v motors that draw 0.5 amps and I want to pulse them with PWM to control their speed.
I've identified the 2 wires that control the motor - and obviously these work in either polarity to make the motor go forward or reverse. I want to just cut one of the wires, and rapidly open and close this circuit to control the speed.
My problem is that a reed relay is not fast enough, a bipolar junction transistor only allows current to flow in one direction, and an analog switch or optoisolator just cannot handle 0.5 amp load.
Does anyone have a suggestion for a bilateral, fast switch that can handle 0.5 amps and 24 volts?
Many thanks.
Many thanks.
