O
Oliver Friedrich
Hallo,
I've discovered a phenomen which I claim to be a fatal PSpice error, at
least something that I don't understand at all.
Try simulate the following netlist
* source 3_029_B01_TLINEVERIFICATION
V_V_DC N00124 0 2
R_R_DC N00124 C1 52
X_T_DC C1 0 0 0 FIM02YHBY PARAMS: LEN=100
R_R_TRAN N00504 C2 52
V_V_TRAN N00504 0
+PULSE 0 2 10n 1n 1n 1m 2m
X_T_TRAN C2 0 0 0 FIM02YHBY PARAMS: LEN=100
To clarify the whole thing. I have two lines of 100m each. Each line is
shorted at the end and fed via a 2V and 52R resistance. C1 and C2 are the
nodes at the input of the lines.
The subcircuit of the transmission line is
*FIM02YHBY is a shielded twisted pair from Gebauer&Griller
*The shield is not modelled as conductor but its influence on
*the line parameters is accounted.
*Model parameter derived by measurement and calculation. Refer to
*document 3-029-B01-D001 for details.
*6.283 is an approximation of 2*Pi
*Both resistors prevent a node floating error.
*Pin Desc
*10 Near end high
*20 Near end low
*30 Far end high
*40 Far end low
..subckt FIM02YHBY NH NL FH FL PARAMS: LEN=1
T NH NL FH FL T1
R1 NH FH {1/GMIN}
R2 NL FL {1/GMIN}
..model T1 TRN(
+r={342m+0*sqrt(s/6.283)}
+l=493.17n
+g={0*(s/6.283)}
+c=45.216p
+ LEN={LEN})
..ends
To my model, skin effect and dielectric losses are prepared but yet not
considered, therefor the 0 in the formulas. All other values I have
measured on a real piece of cable very carefully.
Now make a transient simulation to t=1m. After this time the transient
has settled down to its final state. So the voltage on node C1 and C2
should be the same, cause it is simply a voltage divider from the DC
losses of the line and the source resistors of 52 Ohms.
But my simulation shows a big difference.
C1 is at 793mV which is the correct value assuming that the line has 100m
length and 342mOhm per meter.
C2 is at 1.05V which leads to a DC resistance of 574mOhm per meter.
So what's the story? Why shows the same trasnmission line a DC resistance
of 342mOhm per meter and 574mOhm per meter?
I'm really looking forward to any good explanations, because this
shatters any confidence in the reliability of PSpice.
By the way: I'm running OrCAD Pspice 10.0
Best regards
Oliver Friedrich
V_V_DC N00124 0 2
R_R_DC N00124 C1 52
V_V_TRAN N00504 0
*Pin Desc
*10 Near end high
*20 Near end low
*30 Far end high
*40 Far end low
T NH NL FH FL T1
R1 NH FH {1/GMIN}
R2 NL FL {1/GMIN}
..model T1 TRN(
+l=493.17n
+g={0*(s/6.283)}
+c=45.216p
+ LEN={LEN})
..ends
Best regards
Oliver Friedrich
