Categories
Platforms
Content
Is R3 supposed to be the load? What it is connected to? You show a connection to pin 5 of the opamp, what is that? I would think it should be connected to ground.
Did it? I see no feedback to close the control loop across the opamp. The opamp is operated in an open loop. As I see it, the 741 will immediately go into saturation. Either positive or negative, depending on the input signal.I grounded both and it solved the problem.
Bob, I know that design is being used to boost the output currrent of an opamp. Still for controlling the current some feedback is required. See e.g. here, page 2 (original page # 132)Look at how the transistor bases are connected. They sense the current from the power supply into or out of the op amp and multiply it, much like the pass transistor used on a 3-terminal regulator.
