Bicycle generator
colum
Jul 25, 2013
175
Jul 25, 2013
175
I hurt my knee and need to exercise on my stationary bicycle so I want to attach a DC motor to the wheel to charge a battery
I want to add an analog Volt meter and an analog Ampere meter to observe output.
but when I quit cycling the battery turns the bicycle in the opposite direction .
I would appreciate a simple design to charge a battery with a DC motor and placement of the meters and any Diodes needed
Thanks for reading this and appreciate any help, I will have to do this exercise for the rest of my life
Jeffrey
davenn
14,260
14,260
yes, to be expected ;)
A blocking diode will stop that from happening
You just need to ensure that the diode selected is rated to handle a bit higher current than
what is likely to flow through it.
7,682
7,682
What type of battery are you charging, and at what current? Simply connecting a battery to a generator could either damage the battery or set it on fire.
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
A lithium battery overcharging could set fire to your entire neighbourhood or town. Insurance won't cover the damage.
WHONOES
May 20, 2017
1,217
May 20, 2017
1,217
Arghh, the end of the planet as we know it???????????????
davenn
14,260
14,260
yeah, good point, I forgot about that
Bluejets
Oct 5, 2014
6,922
Oct 5, 2014
6,922
Maybe use a car battery 40Ah and one (or more) of the dynamos that run on the wheel rim with a couple of bridge rectifiers.
I doubt that 15 minutes of pedalling that will do any damage.:D
(Could pass out from the hydrogen fumes if the Op was super fit.)
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Or if you take too big a breath of it you could turn into a Zeppelin and float off the planet. [/Audioguru] :)
