BGA work/rework
Discussion in 'Electronic Design' started by Jamie Morken, Nov 2, 2004.
  1. Jamie Morken
    Jamie Morken Guest
    Hi all,
    I did my first toaster oven soldering including some BGA parts. I think
    5 of the 6 BGA parts soldered correctly but one of them has an obvious
    solder bridge between two pads that is visible when viewed from the
    side. What is the best way to do BGA rework for this? I am thinking
    that I will put the board back in the oven and pull the part off when
    the solder melts and then clean it up with some solder wick and put it
    back on the board and resolder it. The part is an adxrs150 gyro and it
    has a ball pitch of 0.8mm, and a ball diameter of about 0.55mm. I think
    the stencil put too much solder paste on for this part too and that is
    probably why there was a bridge.
    cheers,
    Jamie Morken
