BGA substitute
Discussion in 'Electronic Design' started by nattar, Jan 25, 2005.
  1. nattar
    nattar Guest
    Hi All,
    I was wondering if there is any alternative to BGA type connector?
    Bridging is our main problem after placement and reflow.
    nattar
  2. Bradley1234
    Bradley1234 Guest
    The problem should not be the BGA, but in the process and preparation.
    There is a temperature and duration needed to properly apply the BGA, it
    takes some trial and error with samples, based on the type of BGA package
    and the circuit board and its thickness.
    The technology is solid, so it should work.
    The alternative is the BGA socket, but then the device may not perform right
    at high speeds.
  3. Boris Mohar
    Boris Mohar Guest
    Change your attachment process whatever it is. After number of failed
    attachments done by one previously reliable assembly house I switched to
    another. Problems went away.
