Z
[email protected]
Changed one twice and it was pretty obviously the fault because the
original was intermittent. Both of the replacements from lot # E422
caused horizontal nonlinearity in the left side.
It was impossible to converge, kinda wish I hadn't tried.
It's not clipping, the DC controls move the raster evenly over the
whole screen, nor is there any significant DC offset. I believe the
problem is an insufficient slew rate (high frequency response), so some
may be better than others. Some may converge but I'd rather have an in
spec part.
This happened in a Sony EXR series projection, they and similar Sonys
are the only sets I've ever seen these ICs in, if there are others the
ICs might work, but I dont see how. It's obvious they're not going to
work in these. So don't touch those dials and don't bother
troubleshooting the waveform generator.
Last time this happened to me it was nowhere near as severe and with a
scant ½" of extra overscan the set looked good. This one would've
needed over a full inch, I can't do that.
I thought it worth mentioning because there are alot of these sets
around and most have strong CRTs. What's more, I don't think these sets
get more than ½ a dozen different problems, H tuning cap/Hout and H
regulator, the occasional flyback, diodes in the SMPS/2SC4582. The only
really bad thing I've found is those %&*#$ SRS modules and the set is
good enough I think to use an external sound system. I've only seen one
bad CRT in them ever. When they first came out I thought they were a
bitch to work on, but more recent designs have caused be to do an about
face.
JURB
spec part.
face.
JURB
