B
I didn't insult you and cheese didn't make me think you were lying. Good
luck with everything else..... wow
IMO circle track racers operate in a narrower rpm range than a
dragster. And on tracks like Daytona the pedal stays planted most of
the time, so response isn't a problem.
Another factor is that back when we were talking about they didn't have
the huge carbs they did later. The dual-quads made more power because
they provided the most veturi area.
Steve said:True at Daytona *today*, but I kinda doubt that they ran wide open
through the turns back in the big-block engine, skinny tire, no aero
downforce days of the 60s even at Daytona. I wish they still ran that
way, the racing at Daytona and Talledega today is more boring than
watching grass grow.
That's certainly true. The dual quads on the old cross-ram 413s were
only good for about 400 to 500 CFM each at best.
Maybe you are looking at the US version of the 350 instead of the
Canuck block?. This one was the real Olds engine before the Chev 350
narrow block ones became commonplace. My memory could be failing me
but I just remember they backed the compression ratios down after that
one. The trend was to increase compression more and more in the 60s.
My '69 Cutlass 350 Olds engine ran a 13.8:1 compression ratio and
yup...it needed high octane.
Factory CR on '69 Olds 350 rocket is 9.0 Up to 10.0:1 on the high
output version. 13.8 is VERY high.
The 429 Cobra Jet Super Cobra Jet, or Boss 429 ran 11.3:1
That's the highest stock north american CR I've seen in the sixties.
The Olds Diesel was 22.1:1
Diesels can run from 15:1 up.
y_p_w wrote:
Solar Flare wrote:
High compression needed it [higher octane] to reduce dieseling.
Or forced induction. Pretty much anything that increases the
fuel/air pressure in the cylinders would require higher octane
fuel.
My 2004 WRX with a 2.0L turbo four engine has a compression
ratio of 8.0:1. It sounds low, but then you add the boost.
7:1 isn't uncommon when boost is anticipated. And the other cool
thing about boosted engines is that they have cam profiles with
very
minimal valve overlap so they generally idle as smooth as a
Packard
v12. Whereas a normally aspirated engine with similar performance
would have 10:1 compression and a wild cam that would lope at idle
like a '67 426 Hemi.
Eeyore said:Steve wrote:
What are these quads you talk of ?
clare said:An Olds Rocket is an Olds Rocket - not a Chevy
The 350 OLDS engine came to the Cutlass in 1969. This was the 4.057"
bore rocket, not the 4.00 inch bore Chevy and was used AT LEAST until
1985.
Eeyore said:It pretty much invariably
improves performance.
Graham
Tony said:Four barrel carbs,
51_racing said:Absolutely could not be more WRONG here.
I race(d) in a class that limited compression to 9.5:1.
We could run any fuel we wanted, and time after time, people would put
race gas (Sunoco 110 or Turbo 110) then have to crank their ignition
timing way up only to come close to getting the same performance that
they did using 92 octane pump gas.
Bruce Richmond said:Some how I just can't see a circle track racer saying. "We can get
along fine with less power."
