Best way of multiplexing analog signals?
Discussion in 'Electronic Components' started by Mickey, Oct 25, 2003.
  1. Mickey
    Mickey Guest
    What would be the best (cheap and good) way to demultiplex analog signals
    (mA, V, Ohm)
    that means switch from 16 analog inputs to 1 analog output?
    Can it be done without mechanical or reed relays, and still be satisfactory?
    Thanx
  2. Depends on what you mean by satisfactory. A low voltage, low currant
    signal could be multiplexed with a 4051 CMOS chip.
    @@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@,@@[email protected]@[email protected],@@[email protected]@[email protected]@[email protected]@
    ###Got a Question about ELECTRONICS? Check HERE First:###
    http://users.pandora.be/educypedia/electronics/databank.htm
    My email address is whitelisted. *All* email sent to it
    goes directly to the trash unless you add NOSPAM in the
    Subject: line with other stuff. alondra101 <at> hotmail.com
    Don't be ripped off by the big book dealers. Go to the URL
    that will give you a choice and save you money(up to half).
    http://www.everybookstore.com You'll be glad you did!
    Just when you thought you had all this figured out, the gov't
    changed it: http://physics.nist.gov/cuu/Units/binary.html
    @@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@
  3. Mickey
    Mickey Guest
    Lets say 0 ... 10V and 0 ... 20 mA would be satisfactory.
  4. Data sheet:
    http://www.ee.washington.edu/stores/DataSheets/cd4000/cd4051.pdf
  5. onestone
    onestone Guest
    DG409 from Maxim, +/-20V 16;1 IIRC, if it isn't the 409 it's the 407.
    Al
  6. Mickey
    Mickey Guest
    Thanx, all.
