Best source of thermal noise
Discussion in 'General Electronics Discussion' started by Raven Luni, Mar 19, 2013.
  1. Raven Luni
    Raven Luni
    798
    8
    Oct 15, 2011
    Greetings,
    I'm not 100% sure why I'm asking this but my brain thinks I should know the best / easiest way to ensure an even distribution of random bits that doesnt involve a predictable algorithm.
    So I'm thinking radio noise, but what to do with it......
    How about taking a band that isnt really susceptible to local interference (things like mains hum, computer noise etc. could lead to predictability), pass it to a comparator, XOR it with a square wave and sample the data at 2x the square wave's frequency. Am I right in assuming this would result in a fairly even spread of 1s and 0s?
  2. (*steve*)
    25,501
    2,841
    Yes, noise can be a good source. You want the "frequency" of this noise to be much greater than the rate at which you sample it.
    Essentially you sample it and see if it is above or below some threshold (passing it through a schmitt trigger can be helpful) and use that as the bit value.
    You want to be sure that the signal is sufficiently symmetrical that the chance of getting a 0 is close to the same as getting a 1.
    If you want an 8 bit number you ask it 8 times for a bit (with a delay between "asks"). If the probability of 1 and 0 are different, some numbers will be more common than others.
  3. john monks
    john monks
    693
    3
    Mar 9, 2012
    I believe the best source of random noise is a reversed bias base emitter junction adjust to about 10 microamps. From there you simply amplify the signal, run it into a logic gate, or anything else you want.
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    The thing to remember is once you remove predictability you for all purposes have random... 111111101111 is just as random as 010000000000 or even 010101001011 as long as the outcome is not predictable... Even though our minds suggest that 010101001011 is more random it's simply not in most cases as it's an even distribution of 0 and 1 and that in itself is not random it's generally forced order ;)
    This is important when you set a threshold to distinguish 1 and 0, at that point you are establishing order when setting that threshold, a pesky stuck between a rock and a hard place...
  5. (*steve*)
    25,501
    2,841
    Whilst you can't prove that 0, 0, 0, 0, 0 is not a random sequence of digits, if your source of noise varies slowly then you may be in the situation where your possible random numbers are:
    00000000
    00000001
    00000011
    00000111
    00001111
    00011111
    00111111
    01111111
    11111111
    11111110
    11111100
    11111000
    11110000
    11100000
    11000000
    10000000
    If numbers like 11011101 don't show up (or do so with extremely low frequency) then whilst your source may be random, it has a very poor distribution.
    A reverse biased BE junction, as mentioned above, or a zener diode. Having a high pass filter before your amplifier and detector will minimise issues arising from low frequencies (such as mains hum) that could introduce bias as I have indicated above.
  6. Harald Kapp
    11,957
    2,793
