Best solution for ESD protection of USB port.
Discussion in 'Datasheets, Manuals and Component Identification' started by HansLars, Nov 23, 2014.
  1. HansLars
    HansLars
    Mar 10, 2011
    Beginner here. Im trying to find a good ESD protection IC for a simple USB to RS232 converter.
    I am looking at PRTR5V0U2X and IP4234CZ6, both from NXP.
    To me it seems like most of the specifications are very similar. Both has low capacitance, both are ideal for USB, protects up to 8kv and can protect the data and Vbus lines. The main difference I see is that the IP4234CZ6 has 6 legs and the data lines goes through the IC whereas the PRTR5V0U2X only has 4 legs and the data lines are simply connected to the IC.
    What is the reason for this? Which IC provides best ESD protection?
  2. Harald Kapp
    10,025
    2,138
    Welcome to our forum.
    The converter you link already has ESD protection.
    The IP4234CZ6 also has a built-in series resistor to limit ESD currents. This IC probably gives better protection than the other.
  3. davenn
    davenn Moderator
    13,585
    1,870
    But the USB - serial converter you linked to almost doubles that voltage protection ;)
    So as Harald suggested, you don't need anything else :)
