D
DarkMatter
Not if you understand what you're doing.
I'm sorry, but those of use that understand what we are doing do not
design a 200W transistor into a 200 W circuit application.
One should always use a device at an industry accepted full load,
full duty cycle design point. The device IS capable of operating at
the maximum rating, but the headroom is their for reliability reasons,
pulse conditions, etc.
So, yes, understanding what I am doing means that I would use my 30W
IC amp at 10W or so, and use that to pump my large power devices, and
only utilize THOSE at a power level much less than that at which they
are rated. For caps, it can be as high as twice the voltage, for
other components... say power resistors, it is around half. The heat
generated by a 25W resistor AT 25W is far far too high to have it
contained in a rack chassis. Pumping only 12W thru the "25W" device,
however, makes the heat it exhibits much more manageable.
Got clue?
For you not to know that is quite a tell.
