D
DaveC
White "tooth" paste kind, or clear greasy "hair stuff" kind?
DaveC said:White "tooth" paste kind, or clear greasy "hair stuff" kind?
DaveC
[email protected]
This is an invalid return address
Please reply in the news group
Michael A. Terrell said:Make sure you use all the other over hyped crap so it doesn't get
lonely.
Guy said:Neither.
http://www.ksbrainstorms.com/index.php?pagename=Arctic_Silver_5_Review
http://www.xbox-connection.com/hostedsites/hotlinesrc//reviews/arcticsilver5.php
http://www.overklokking.no/annet/arctic_silver_5/eindex.html
http://overclockersclub.com/reviews/articsilvercermaiquereview.php
http://www.modsynergy.com/Review 109.htm
Guy Macon, Electronics Engineer & Project Manager for hire.
Remember Doc Brown from the _Back to the Future_ movies? Do you
have an "impossible" engineering project that only someone like
Doc Brown can solve? My resume is at http://www.guymacon.com/
Miles Golding said:This question is timely for me. I'm about to build my own (first time) and
have bought an Intel P4 2.4 /heatsink pack. Having researched a fair bit
before starting the job, I discovered thermal paste. Is it really
necessary?
I don't intend to overclock, so will the thin film already attached to the
base of the heatsink do the job adequately?
Miles
Guy Macon said:I would find it easier to believe that it was overhyped crap if
I wasn't typing this on a quad processor Compaq Proliant that
has the CPUs runnin 10 degrees C cooler since I replaced the
OEM heat sink compound.
Floyd Davidson said:First, if you saw that much difference, then it is *obvious* that
the initial installation with OEM heat sink compound was flawed.
10C is *way* too much!
Watson A.Name - Watt Sun said:[email protected] mentioned...
longer making good contact with the heatsink. Some of the worst
failures were the ones that used nylon screws. Once they get loose,
the device gets hot and melts the screw, and then it's all over very
quickly. That's probably why many equipment makers put loktite thread
sealant on the screws and nuts to prevent the loosening.
NAPA Item# 765-2569
Copper Anti-Seize Lubriant
Michael A. Terrell" ([email protected]) said:Make sure you use all the other over hyped crap so it doesn't get
lonely.
DaveC said:and you recommend this as a head-sink compound for semiconductors?
If there is a thin rubbery film already there on the heatsink surface, then
you don't need to add anything else, it will work fine. But if the heatsink
is bare (i.e., a plain metal surface), then it's absolutely necessary to use
some kind of thermal paste between heatsink and CPU. No matter how smooth
the surfaces are, there will always be small imperfections and particles
that will not allow a good thermal path between the two. That's the purpose
of the paste. But in your case it's not necessary as your heatsink already
has thermally conductive film on it.
cheers,
Costas
_
