Best Grounding Scheme For Pwm Electromagnet, Pwm electromagnet digital/analog signals
Discussion in 'General Electronics Discussion' started by fernandomierhicks, Aug 20, 2012.
  1. fernandomierhicks
    fernandomierhicks
    4
    Mar 5, 2012
    Hi:
    I have a setup were I run a electromagnet with a PWM signal using 20 volts, usually at low dutycyles < 20%. PWM frequency in the low kHz range.
    Around this electromagnet I have various sensors, cirucits etc.All of this (electromagnet and circuits) is inside a metal chamber (faraday Cage). I need to run some signals outside this chamber, analogue and digital.
    The power supplies for the Electromagnet and the other circuitry are ground-isolated.
    I want to reduce the noise that the Electromagnet is going to produce on my signals both because of the pulsing and the EM interference.
    I was thinking of using coaxial cables for all my signals, using a star scheme once the wires are inside the chamber, so I will have a dedicated ground wire.
    Should I also use coaxial cable for the electromagnet leads? Should I ground the shield on this wire to my general "signal ground"?
    Should I ground both ends of my signal wires shield?, lets say to the frame?
    Any other suggestion recommendation is appreciated, wire types are flexible.
    Fernando
  2. (*steve*)
    25,480
    2,827
    If you use coaxial cable, I think the best bet is to connect the coax shield to the cage where it enters/exits.
    On the other hand, you *may* be able to get away with a simple twisted pair.
    If your signal level is reasonably high, and the impedance low, you will obviously have less problems than in the reverse case. Understanding the signals is key.
