best electronic circuit simulator
shibas
Feb 13, 2013
14
Feb 13, 2013
14
Which is the best electronic ciruit simulation software currently available?
Harald Kapp
13,728
13,728
There is no such thing as the best circuit simulator software.
Every software has it's advantages and it's drawbacks. To find the software best suited to your expectations and needs, you will have to define the requirements and/or limits.
An example: A software may be free (good for your purse), but may be limited in features (bad if you need them). Or it may have all the features you want (good for you), but be expensive to buy (bad for your purse).
Personally, I use LTSPICE IV. This is software of the first kind:
- free
- rather limited library of components
But it has all the typical SPICE features plus a graphical editor and waveform analyzer. Missing models can be integrated manually into the existing LTSPICE IV libraries or you can add you own libraries.
ICGengineerTech
Aug 15, 2012
58
Aug 15, 2012
58
OrCAD is easy enough to learn but it can get really complicated the more you learn.
~Bill
ICGengineerTech
Aug 15, 2012
58
Aug 15, 2012
58
Electronic Workbench works easy too and it is much cheaper.
The thing is as Harald Kapp said above, each has it's ups and downs. But mainly they all take a lot of tweaking to get working properly.
~Bill
techna
Jan 18, 2013
9
Jan 18, 2013
9
If you need microprocessor & microcontroller simulation software, Proteus is a good one.
Rleo6965
Jan 22, 2012
585
Jan 22, 2012
585
Circuit Wizard for beginners.
LtSpice IV for experienced in Electronics.
