Braeden Hamson
- Feb 18, 2016
- 240
- Joined
- Feb 18, 2016
- Messages
- 240
I'm on an FSAE team that's making an electric car. We're making a battery pack out of discrete 18650 cells. In the pack every cell must have a fuse between it and its bus bar. So we have to size the fuse and, rate it for the appropriate current. Somewhere from 300A-200A at ~1V. I need to refine my calculations on heat input into nickel fuses. Right now I have to competing ideas as to the design of the power supply.
Option 1:
I take a variable AC power supply and connect it to a modified microwave transformer with the secondary cut out and a few turns of thick wire to get a high current power supply. Then rectify the AC into DC. The trouble is I need some really, really, beefy diodes. I can then vary the voltage of the supply to vary the current output. I will probably make some logic to make it constant current.
Option 2:
I use a car battery, they can do high current. Then build the mother of all buck converters. This idea is less fleshed out, I don't know what the best (good current control, lowish noise and, simplicity would be nice, in that order) method of controlling the power out of the battery would be.
Option 3: (Bonus round?)
Supercaps? An electronics surplus store near me has at least 40 of them and they're about the size of a tall beer can.
As always thank you for the help
Option 1:
Option 2:
