Best Audio Clipping Ind Circuit
Discussion in 'Electronic Design' started by Paul kent, Feb 10, 2011.
  1. Paul kent
    Paul kent Guest
    I am driving a 12W audio amp module from a PC soundcard and would like
    to fit an _adjustable_ clipping indicator.
    Would like to keep the circuit as simple as possible. Not a hi-fi
    application. It's just because the PA speaker is in another room and I
    cannot hear if distortion occurs.
    What are the pro's and cons of the circuits below? Any other
    suggestions?
    http://electroschematics.com/5942/audio-clipping-indicator/
    http://electroschematics.com/302/peak-indicator-circuit-schematic-tlc272/
    The next is simple, but not adjustable, and would need to be modified
    for a 12VDC supply.
    (fourth diagram down)
    Thnak you for any advice.
    Paul Kent
  2. Paul kent
    Paul kent Guest
    Nice, but I want a small circuit I can build into a device. Sorry, if
    that wasn't clear.
    Paul Kent
  3. This isn't too bad, but it will vary in sensitivity with the battery
    voltage. A low power regulator driving R2 and R4 will fix that.
    There's a very long list of things wrong with that one.
    Same link.
    Since this isn't hi-fi, feed the speaker output to a 47 Ohm resistor,
    then to a bridged rectifier, then to a string of cheap LEDs. The more
    LEDs in series, the higher the illumination threshold. It will probably
    be around 8 red, 6 green, or 4 blue/white. 12W RMS into 8 Ohms is the
    typical quoted output of a bridged amplifier running on 14.4V.
  4. Paul kent
    Paul kent Guest
  5. Not bad. A 4.7V zener diode may be wrong for a 12W amp. An adjustable
    voltage divider may be better.
  6. Ralph Barone
    Ralph Barone Guest
    I had long forgotten a circuit I did decades ago to do exactly this. I've
    just written it up and added it to 4QD TEC:
    http://www.4qdtec.com/Audio/SPPPI.html Speaker powered Peak Program
    Indicator
    Enjoy![/QUOTE]
    Do you get a long enough optical pulse out of the LED to "see" the
    clipping, or should you throw a small capacitor somewhere in the circuit?
