Bench PSU
Discussion in 'Power Electronics' started by HellasTechn, Jan 2, 2016.
  1. HellasTechn
    HellasTechn
    1,559
    215
    Apr 14, 2013
    Hello every one and Happy New Year !
    I have in my hands a big transformer ripped from an old HiFi system (SONY STR-W550).
    I am thinkin to use this to make a bench power supply. What circuit would you Recommend
    that i use ?
    I have searched the net for info about this transformer and the only thing i found is a diagram of the windings from the STR-W550 repair manual.
    The winding in the red box gives 36V and has fuses rated 6.3 Amps. I thought that 36V at 6A would make a nice bench psu.
  2. Arouse1973
    Arouse1973 Adam
    5,170
    1,092
    Dec 18, 2013
    Happy new year to you also. What do you want your power supply to be able to do? Adjustable current and voltage etc.? Output voltage and current value? Voltage drop sense terminal? Voltage and current reading output?
    Adam
  3. HellasTechn
    HellasTechn
    1,559
    215
    Apr 14, 2013
    Well for sure i would like voltage control and if it does not make the circuit too complicated Current limiter. About voltage drop sense i am not sure, where would that help ?
    P.S. i could measure the rest of the windings to see the voltages if that could help.
  4. Arouse1973
    Arouse1973 Adam
    5,170
    1,092
    Dec 18, 2013
    If you have a longish cable supplying a few hundred mA, and you set your PSU to say 12 Volts. You may only have 11.5 actually at the load. Using a sense terminal you can remove this error.
    Adam
  5. HellasTechn
    HellasTechn
    1,559
    215
    Apr 14, 2013
    Isnt that what we call "regulated" psu ?
  6. Arouse1973
    Arouse1973 Adam
    5,170
    1,092
    Dec 18, 2013
    How does the power supply know what voltage you have at the end of a pair of wires under load?
    Adam
  7. HellasTechn
    HellasTechn
    1,559
    215
    Apr 14, 2013
    I dont know. I am not sure i understand the question.
    Some kind of feedback loop?
  8. Martaine2005
    Martaine2005
    3,996
    1,085
    May 12, 2015
    Hey Constantine,
    Adam mentioned length of wires.. Think resistance..
    At least that is what I thought of..
    The longer the wire..........
    Martin
  9. Bluejets
    Bluejets
    5,528
    1,163
    Oct 5, 2014
    The winding details may be in the drawing but too small to see.
  10. HellasTechn
    HellasTechn
    1,559
    215
    Apr 14, 2013
    I am not sure.
  11. HellasTechn
    HellasTechn
    1,559
    215
    Apr 14, 2013
    Not really.
  12. Martaine2005
    Martaine2005
    3,996
    1,085
    May 12, 2015
    Well, longer wires have more resistance..That is all I can think of..
    Martin
  13. HellasTechn
    HellasTechn
    1,559
    215
    Apr 14, 2013
    In a PSU with high current capabilities i doubt that cable leignth matters, i think he is referring to the voltage drop because of the load.
  14. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    There are four wires, two for the power and two for the voltage sense. The supply ups the voltage to take account of the voltage drop. The sense wires take very little current and so the voltage drop in them is negligible. Normally, they are connected to the power supply output with resistors so that if they are not used, the voltage is controlled at the output of the supply.
  15. Arouse1973
    Arouse1973 Adam
    5,170
    1,092
    Dec 18, 2013
    Yes. Without the sense terminal, the power supply does not know what the voltage is at the load end. I mentioned it because it can be a good feature to have at times.
    Adam
  16. HellasTechn
    HellasTechn
    1,559
    215
    Apr 14, 2013
    Ok :)
    Do we have any diagrams ?
  17. Arouse1973
    Arouse1973 Adam
    5,170
    1,092
    Dec 18, 2013
    I don't have any on me, but I am sure we could design something together.
    Adam
    Martaine2005 likes this.
  18. HellasTechn
    HellasTechn
    1,559
    215
    Apr 14, 2013
    Well Thank you for the offer, yes why not ! That will take some time though.
  19. Arouse1973
    Arouse1973 Adam
    5,170
    1,092
    Dec 18, 2013
    I'll see what I can come up with. In the meantime for any of the other geniuses on here that wish to contribute then please do. I have been known to over complicate things at times :)
    Adam
  20. HellasTechn
    HellasTechn
    1,559
    215
    Apr 14, 2013
    We can do this i am sure ! what kind of e.t. are we after all ?
