Bench PS
Discussion in 'Electrical Engineering' started by Jim Douglas, Aug 5, 2004.
  1. Jim Douglas
    Jim Douglas Guest
    Am looking for a good, read inexpensive, bench power supply. +-5, +-12,
    0-20VDC, and 0-20?VAC. Has anyone ever used a PC powersupply for the bench?
    Jim Douglas
    http:\\www.genesis-software.com
    Latitude 32.5818
    Longitude -96.5412
    Elevation 497
  2. KWS
    KWS Guest
    What do you require with regard to power for the 0-20VDC?
    and 0-20?VAC.
    A variac might be your best bet.
    No reason you cannot, but you might want to fuse it locally if you are
    working on low power circuits.
    Suggest you try ebay. Be certain to check out your purchase carefully,
    especially for load regulation and turn on conditions (i.e. +5 goes to +12
    at turn on....bad for most 5VDC circuits).
    Ken
