After much research today, availability of a matched set has been narrowed to LM317+/LM337- regulators. These would have a cap. of 1.5A of output current. Which is not bad in retrospect. My wants exceed my capabilities as always
I did find a
nifty little board already made up which has some of what I want out of a power supply, I was thinking for the ~$8 they want for it, it might not be a bad board to learn on and modify. Here is the schematic below. The transformer is not included, but if the output caps are only 25v, I doubt I could use a higher value for the xformer. Luckily, this kit is not assembled so I could swap out the caps that are rated too low...
For academic purposes, can someone explain how this circuit allows more current to flow to Vout while maintaining Vreg?
As always, thank you for your patience and support!
