Belts joints
Discussion in 'Electronic Basics' started by shafi, Sep 18, 2006.
  1. shafi
    shafi Guest
    Dear Sir,
    How r u ???
    Can you tell me why we make the joint of belt conveyors on angles ???.
    Why we do not make belt joints Straight ????.
    I will be very thankfull to yoyu if you rweply me soon.
    Best regards,
    SHAFI
  2. Eeyore
    Eeyore Guest
    Many reasons in fact but a butt joint ( a straight one ) is notoriously weak and
    prone to damage.
    Graham
  3. atec 77
    atec 77 Guest
    Drive over a rail xing , at an angle and directly .
  4. jasen
    jasen Guest
    I've seen straight joins done, there was this metal thing with hundereds of
    rings on each end of the belt and a wire was through the rings linking the
    ends.
  5. Rich Grise
    Rich Grise Guest
    Because if the joints were orthogonal, they would go, "SLAP! SLAP! SLAP!..."
    and the joint would fail much sooner.
    Good Luck!
    Rich
