T
Tim Lamer
Can someone familliar with Beldens "Beldfoil" aluminium-polyester
screening foil please tell me how it is constructed?
It is typically used with a drain wire in their shielded cables.
What I need to know is if a voltage is applied to the drain wire, is
it conducted throughout the entire surface area of the Beldfoil
screen?
To rephrase, is the film continuously conductive? Or does it have
discontinuities (laps, etc.) spanned by the drain wire?
Am I correct in assuming the poly part faces inward toward the signal
wires?
The point is, I want the entire screen to carry the current, not just
the drain. I realize it's not normally used this way, but it is an
experiment.
Thank you for any advice.
Tim Lamer
screen?
wires?
experiment.
Tim Lamer
