beginner struggling with a opamp
Discussion in 'General Electronics Discussion' started by Simone, Mar 2, 2017.
  1. Simone
    Simone
    6
    Mar 2, 2017
    I tried to design a schematic with opamp to add and select through a pot, the dc-offset at a sine wave. I would like to have unity gain in exit but my schematic has a lot of gain. Why? I can't figure out , which is the formula for gain in this schematic? Thank you
    [​IMG]
    [mod note: added full image to post]
  2. davenn
    davenn Moderator
    13,808
    1,943
    to provide unit gain ( another term for this in op-amps is a buffer) the output is connected directly to the input NO resistors between input and ground nor to the output ... any resistors in those positions will provide gain that is above unity
    have a look at this video ... op-amp operation is explained well
    cheers
  3. davenn
    davenn Moderator
    13,808
    1,943
    also, that diode in the output may be around the wrong way
  4. Simone
    Simone
    6
    Mar 2, 2017
    thanks for the answers. The output diode is a forget of the rest of the circuit, but it works. Even removing the diode, when i do a simulation with spice, for a input sine wave of 1 volt I find on output a 4 volts wave (the gain is not the relationship between r7 and r8, should not be 1?). if I remove r7 and r8 and put the output in feedback (buffer, in figure) with the inverting input and then to ground, spice does not make the simulation, as there was an error. Is it a spice error ? thanks
  5. Simone
    Simone
    6
    Mar 2, 2017
    ok, sorry
    I figure out the spice simulation , there is a bad ground connection in feedback. But why with r7 and r8 it gain so much?
  6. LvW
    LvW
    604
    146
    Apr 12, 2014
    What is the meaning of "so much"? Theoretically, the maximum gain will be (1+R7/R8).
  7. Harald Kapp
    11,413
    2,619
    The '-' input of the opamp and the output of the opamp are connected to ground. This is wrong. Connect the output of the opamp to the '-" input without ground connection.
    R1 is not necessary, remove it. Input current will flow through the potentiometer (modeled by R4, R5 and R7).
  8. davenn
    davenn Moderator
    13,808
    1,943
    no, if you had watched the video, you would have learnt that the gain is related to your R7 and R8
    Gain = R7 / R8 + 1 = 100,000 / 100,000 + 1 = 100,000 / 100,000 = 1, and 1 + 1 = 2 so that configuration will give a gain of 2
    that is likely to vary a little bit because your resistors will not be exactly 100k each
    in the unity mode circuit, you should NOT be grounding the feedback loop as all that is doing is grounding your signal
    and that is why the simulator did what it did
  9. Harald Kapp
    11,413
    2,619
    The issue with R7/R8 is that your DC offset will also be amplified.
    Put a capacitor (e.g. 1µF) in series with R8. This will block DC. You then have DC gain = 1, AC gain = (1+R7/R8) (see LVW's post #6).
  10. Simone
    Simone
    6
    Mar 2, 2017
    Sorry,
    I don't understand: gain = r7 / r8 + 1 = 1 + 1 = 2 wave input is 1 volt. 1Volt 2 * gain = + 2 volts + DCOffset (I need a variable dc offset). Why i have a wave of 4 volts (+ dc offset) in output? thank you vary much
  11. davenn
    davenn Moderator
    13,808
    1,943
    is that AC or DC ? and as Harald said .... did you account for the DC offset and how that will affect the output reading ?
  12. Harald Kapp
    11,413
    2,619
    Are these measured values or simulated values? If measured: did you check the circuit and the components, especially R7=R8?
    A quick simulation in LTSPICE shows the expected behavior:
    Note the 10 µF capacitor to make DC gain =1. The offset is part of the voltage surce's definition (1 V). DC part of the output voltage is 1 V -> DC gain = 1
    AC part of the input voltaeg is 0.5 V (peak), AC part of the output voltage is 1 V (peak) -> AC gain = 2.
  13. Simone
    Simone
    6
    Mar 2, 2017
    With 10 mf capacitor it is improved but i still read 4 volts in output
  14. Harald Kapp
    11,413
    2,619
    You don't.
    What you read is +-2 V at the output with an input of +-1 V. That's a perfect gain=2 circuit.
    Plot the input voltage, too, to see this very clearly.
  15. Simone
    Simone
    6
    Mar 2, 2017
    ok, i'm sorry , with capacitor it work fine. Because it is 2 volt peak to peak so its right. thanks a lot.
  16. Audioguru
    Audioguru
    3,233
    702
    Sep 24, 2016
    Your latest circuit does not need R1.
  17. davenn
    davenn Moderator
    13,808
    1,943
    deleted
