Before I can work on the electronic projects I had to do this project, my new work area. No, I'm not into surrealism or Frank Lloyd Wright and it's not a re-purposed upright piano. But I am into minimalism, as in keeping the noise down while I built this in my apartment, on a small budget. I would rather spend the money on electronic supplies.
This size and shape came out of the fact that I don't have a work shop, not a lot of tools and not a lot of space. I bought a lot of the wood cut to size, the main bench, top shelf and backboard, all 2'x4'. I had to buy and cut the trim around the, the shelf supports and the lower shelf. I bought the folding "banquet table" legs used and built around them. If you look close at the table in progress image you can see I used half of a hinge to affix the support of the top shelf to the bench.
I like how it came out. It's too bleach white though. I will have to find some discounted paint with some color to spruce it up or I will get "snow blindness".
For lights I bought a roll of bright white LEDs so want to cut a strip and put it under the top shelf against the front edge. I also want to get a four outlet box and fix it to the right side of the lower self support to plug my gear into. As you can see in the pictures I have my 2 in 1 solder station patiently waiting to take up it's place on the bench.
