Bee Venom Collector
Discussion in 'General Electronics Discussion' started by Papaflesas, Apr 24, 2019.
  1. Papaflesas
    Papaflesas
    Nov 16, 2018
    Hello,
    I am still a freshman in electrical engineering, so I know a bit more than the basics, but I have to create a device for some personal use.
    I want to make a bee venom collector.
    From what I know this device delivers an electric square pulse every few seconds and stops after a 45-minute period.
    The pulse is then transfered in a panel made out of steel.( The photo below present it in brief detail ).
    Some other chatacteristics are:
    Power: 11 - 15V battery or power adapter.
    Output voltage to collector frames: AC 15 - 40V (adj.)
    Output frequency: 300 - 4500 Hz ( (adj.)
    Consumption: 80 mA.
    Reverse voltage protection.
    I have heard that is not that hard to be made, thus I am still a rookie in circuits.I would really appreciate your help.
  2. Alec_t
    Alec_t
    2,950
    803
    Jul 7, 2015
  3. duke37
    duke37
    5,364
    771
    Jan 9, 2011
    A diode will be adequate to provide reverse voltage protection.
    I do not understand the output requirement. Either it has an ouput frequency or a pulse every few seconds. A microprocessor could give the frequency and duration times.
    A 555 or 4093 can make a simple oscillator to drive a pair of fets at the required frequency.
    You will need a freshman in electrical engineering to design a transformer. A ferrite core is probably suitable, I use TV line output transformer cores for much higher powered cases.
    Output voltage variation would be easier done by switching transformer taps.
  4. Papaflesas
    Papaflesas
    Nov 16, 2018
    Alright, I will try to do it with the 555 . Thanks
  5. davenn
    davenn Moderator
    13,813
    1,945
    thread oved as it isn't homework :)
