Hi Everyone ,
I am new to electronics, and I'd like some help understanding this simple circuit if you don't mind.
Here's the circuit:
My understanding of the basic function of this circuit is to charge the capacitor using the solar cell, and when the FLED reaches a certain voltage, it goes on which causes the PNP transistor to conduct which causes the NPN transistor to conduct. Then current from the capacitor flows through the battery until the voltage is low enough for the transistors to go "inactive". That's my basic understanding.
I'm confused with the orientation of the solar panel and the capacitor. If the electrons in the negative side of the solar panel are flowing to the negative side of the capacitor, how would those electrons flow through the FLED in the right direction?
Also, how would the capacitor release its charge if the solar panel is still connected?
Thanks for reading. Any help would be appreciated!
-Henri
Here's the circuit:
-Henri
