BC337 alternative
Discussion in 'General Electronics Discussion' started by adel2014, Dec 10, 2013.
  1. adel2014
    adel2014
    22
    Dec 1, 2013
    hello; I have in a schematic ten BC337 that drive a common anode 7 segments LED ; could i exchange them with an IC ?
    thanks
  2. (*steve*)
    25,481
    2,830
    Show us the circuit. Depending on how they are connected the answer may well be yes.
  3. adel2014
    adel2014
    22
    Dec 1, 2013
    here
    here it is ; u1=pic16f876a ; u2=4028
      File size:
      137.8 KB
      206
  4. (*steve*)
    25,481
    2,830
    I assume those are common anode displays?
    Also I note that you don't show the collectors of the BC337s connected to anything and the load is in the emitter of the BC337 (usually it would be in the collector).
    You would normally use a PNP transistor for this and invert the logic of your column logic, but I can see why you've done this.
    Most driver chips I've seen have the emitters connected together, so they won't work in this environment.
    I think you could replace the BC337s with something like
