O
[email protected]
Well at long last the water system is in (mostly) and functioning.
Specifications:
1- 56 ft deep well (homemade/installed in 3 days) 2" PVC cased water well
with 120 volt 1.5 hp jet pump operated by generator.
2- 550 gallon water storage tank at ground level with float valve for
automatic filling when when deep well pump is operating.
3- Dual 12 volt DC shurflow pumps parallel plumbed, yielding
`~4 gallons/min flow supply water to outside faucet, tub, bath sink,
kitchen, and toilet when desired by opening a valve.
4- .5 hp water pressure boaster pump, 120 volts. This pump feeds water from
the storage tank around the 12 volt pumps to outside faucet, tub, bathroom
sink, kitchen and toilet when desired by opening a valve and it operates
when generator is running without any operator intervention saving the
batteries.
5- 250 gallon rain water storage tank with rainwater roof catchment system,
roof washer diverter and 12 volt DC shurflow pump supplying water to the
toilet, outside shower and faucet.
Specifications:
batteries.
