Bayonet motion sensor light adapter
Discussion in 'Hobby Electronics' started by Falkon, Jan 31, 2006.
  1. Falkon
    Falkon Guest
    Hi All
    I am looking for a motion sensor that simply plugs into to the bayonet
    fitting of an existing light.
    Sort of like this product:
    http://www.jaycar.com.au/productVie...&pageNumber=&priceMin=&priceMax=&SUBCATID=498
    or http://tinyurl.com/c87ck
    but with a motion sensor as well as a light sensor.
    Any ideas if such a product exists and, if yes, where I can find it?
    I know there are night lights (that plug into an electrical socket) that
    perform the same function but they aren't bright enough for my needs.
    Cheers
    Falkon
  2. Arlec ( and others ) make PIR sensor lights for outside security lights,
    with a bayonet fitting for direct plugging to existing fittings.
    Remove the lights and plug in some other compatible appliance.
    Most hardware stores carry them.
    Regards,
    Adrian Jansen adrianjansen at internode dot on dot net
    Design Engineer J & K Micro Systems
    Microcomputer solutions for industrial control
    Note reply address is invalid, convert address above to machine form.
