battery switch over help?
Discussion in 'Power Electronics' started by sazml, Sep 27, 2019.
  1. sazml
    sazml
    4
    Sep 27, 2019
    Hi
    Im very new to electronics and have been thinking about modifying some fpv video goggles i have.
    The product contains an internal battery and mostly this is sufficient for my use but my plan for longer use is to fit an external battery that could power the unit when the internal battery is low.
    I need a switch that is safe to connect 2 lipo battery's to and when flipped swap the power from one battery to the other.
    Pete
  2. sazml
    sazml
    4
    Sep 27, 2019
    Is a simple spdt switch wired this way safe and acceptable ?
  3. sazml
    sazml
    4
    Sep 27, 2019
  4. dave9
    dave9
    899
    229
    Mar 5, 2017
    It's a bit large, if putting it on the goggle housing, but would work otherwise.
    However I can't see the banggood pics very well but from your pic it looks like you'd be wiring it wrong. Each battery would go to the two end contacts on the switch and the center contact would go to the goggles. You can confirm this with a multimeter once you have the switch.
    sazml likes this.
  5. sazml
    sazml
    4
    Sep 27, 2019
    thank you David very much appreciate the help
  6. Audioguru
    Audioguru
    2,815
    633
    Sep 24, 2016
    The very high current rating of the Chinese switch indicates that it has silver contacts that tarnish when switching low current. Then the switching fails soon. I have always used American or European switches with low current gold contacts that last forever when switching low current. The high current silver contacts and the low current gold contacts cost the same.
