Battery Specs for a Camera
Discussion in 'Power Electronics' started by mm391, Jun 30, 2013.
  1. mm391
    mm391
    Jun 30, 2013
    I am looking for a new battery for my Canon Compact Camera. The old battery was a 3.5v 870mAH 3.1Wh(Li-ion). I have found some online that have the following specs:
    3.5V 1000 mAh
    3.7V 870 mAh
    Would these be suitable? What is the difference in voltage and mAh?
    Cheers
    MM
  2. davenn
    davenn Moderator
    13,833
    1,950
    hi mm
    welcome to the forums :)
    the 3.5V 1000mAh would be fine
    the 1000mAh instead of the original 870mAh just means it will last a little longer before need a recharge
    cheers
