Battery Question
Discussion in 'Electronic Design' started by Jim Thompson, May 11, 2007.
  1. Jim Thompson
    Jim Thompson Guest
    CR2025
    What is the series resistance new? I can't seem to locate a real
    specification anywhere.
    Thanks!
    ...Jim Thompson
  2. James Arthur
    James Arthur Guest
    <abse dropped (for Google)>
    This is about as good as you'll find:
    http://data.energizer.com/PDFs/cr2032.pdf
    FWIW, Sony says "Recommended pulse drain: 12mA."
    Best regards,
    James Arthur
  3. Jim Thompson
    Jim Thompson Guest
    ...Jim Thompson
  4. James Arthur
    James Arthur Guest
  5. LVMarc
    LVMarc Guest
    JT,
    its going to be Voc/Isc id pulse test it to be accurate.
    Marc
  6. The Phantom
    The Phantom Guest
    I have a used CR2025. It's not completely dead, with open circuit voltage
    of 2.8 volts. I also have a brand new CR2016 and CR2032. The CR2016 is
    thinner than the CR2025 and the CR2032 is thicker than the CR2025. I
    measured the impedances of all three and got these results:
    Frequency CR2016 CR2025 CR2032
    20 Hz 63.5 92.6 9.1
    100 Hz 58.0 82.6 7.9
    1 KHz 47.0 48.0 7.1
    10 KHz 18.9 33.0 4.9
    100 KHz 4.8 29.2 3.2
    1 MHz 2.6 27.4 2.6
    The measurement was done with 10 mV across the cell, and the impedances are
    given in ohms.
    I would guess that a new CR2025 might lie between the CR2016 and the
    CR2032.
  7. Ross Herbert
    Ross Herbert Guest
  8. Oppie
    Oppie Guest
    Nice testing there. What instrument(s) did you use?
  9. Jeff L
    Jeff L Guest
    Panasonic used to have data. Check:
    http://www.panasonic.com/industrial/battery/oem/
    I've drawn 180+ mA out of a CR2032 and ended up with a reasonable lifespan.
    Application was a little demo card with a bunch of
    LED's controlled with a AVR uC . The capacity specs are actually pretty
    accurate, even for really low draws. I have a machine that used a big AA
    sized lithium cell, and I didn't have replacement, so I soldered the wires
    to a new Panasonic CR3032 (we had a ton in stock). About a year and a half
    later, the battery died - surprised at the short life I measured the current
    draw - it worked out that the battery was to be dead right around that time!
  10. The Phantom
    The Phantom Guest
    Wayne-Kerr 6440B. See the images on ABSE.
  11. Phil Allison
    Phil Allison Guest
    "The Phantom"
    "Oppie"
    ** What a " wank err " !!!! ( pun intended )
    http://www.waynekerrtest.com/global/html/products/LCR/6430 6440.htm
    I found impedance figures near identical to those given for the CR2032 (
    using a new example of same ) with just my bench sine wave generator, a
    scope and a few low value resistors.
    ........ Phil
