Battery Powering a CPU fan?
Discussion in 'Beginner Electronics' started by [email protected], Dec 19, 2003.
  1. I'm trying to figure out a lightweight ventilation solution for my
    terrarium[1], and am considering a battery powered 80mm fan as a solution.
    I don't need a lot of circulation, just a little flow.
    How many days could an 80mm fan run off of a 9v battery? Is there anything
    (ie, resistor) that I can put between the two to lengthen the life of the
    battery?
    Are there any commercial solutions that would meet my needs?
    [1] I have a 3"x3" opening at the top back of the terrarium hood[2],
    which I plan to cover with a screen and use for venting. I'm thinking
    I can cover it with a cpu fan pushing air in, and the air can exit using
    the various other nooks and crannies in the lid.
    [2] There's also an 8W Fluorescent light on the hood. Is there a simple
    way to make use of the power to power a CPU fan?
    "Listen to those who are seeking the truth; doubt those who have found it."
    Andre Gide
    http://www.memeticcandiru.com
  2. As a followup, I've found a solar powered battery charger on Ebay that
    outputs a small ammount of juice. This would be ideal, as it would just
    run off of the residual light off of the hood lamp.
    It's at:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3164930751&category=3240
    Does anyone have a feel if it would power a 80MM fan or not? Would I be
    better off considering a slightly smaller fan?
    The rank and file are not philosophers, they are not educated to think for
    themselves, but simply to accept, unquestioned, whatever comes.
    -Susan B. Anthony
  3. Rat Patrol
    Rat Patrol Guest
    Why not buy a voltage regulator that steps down 120 to >>>>6,9,or 12 volts
    instead of buying batteries?
    @Radio Shack !
    Jd
  4. It sounds like numerology to me, kindly take this crap to an appropriate
    newsgroup. -Daryl S. Kabatoff
  5. di0nysus
    di0nysus Guest
    This is basic math at best.
    Just what is "real" math?
