Battery Pack Question
Discussion in 'Power Electronics' started by Chris Saathoff, Jan 26, 2017.
  1. Chris Saathoff
    Chris Saathoff
    4
    Jan 26, 2017
    I am new here so had a few questions on a battery pack that I have that needs the batteries replaced. The battery pack has 2 6v 12ah batteries inside in series with some sort of electronic device attaching the positive and negative terminals together on one end, what is this? Secondly, could I just use 1 12v 12ah battery instead of linking 2 6v together? Thoughts?
    Thanks in advance for your help.
    Chris
  2. davenn
    davenn Moderator
    13,429
    1,806
    a fuse
  3. (*steve*)
    25,270
    2,718
    If you replace it with a single 12V battery, wire a fuse of a similar rating in series with it.
  4. Chris Saathoff
    Chris Saathoff
    4
    Jan 26, 2017
    How do I tell what rating this fuse was?
    Chris
  5. (*steve*)
    25,270
    2,718
    What is written on it?
    Edit: ah, it's a polyfuse. Just desolder it and reuse it.
  6. Chris Saathoff
    Chris Saathoff
    4
    Jan 26, 2017
    Is there any advantage to the two 6v batteries over one 12v?
    Chris
  7. (*steve*)
    25,270
    2,718
    They provide a handy place to connect that polyfuse. Aside from that, not much.
    davenn likes this.
  8. Chris Saathoff
    Chris Saathoff
    4
    Jan 26, 2017
    Ha! Well sounds as if I can fix this $800 battery pack for less than $20 then,(just a little bit of mark up) I appreciate all the help!
    Chris
    (*steve*) likes this.
