Battery Load Test, constant current circuit help.
Discussion in 'Power Electronics' started by Andytester, Aug 14, 2014.
  1. Andytester
    Andytester
    10
    Aug 14, 2014
    Hi All
    This is my first post, hope it makes sense. I'm trying to test some 26-28v batteries for load capacity and I'm hoping to use this simple circuit to provide a 10A DC constant current load. I've used this circuit successfully for a while testing some 7v NiCd Battery's at 5A, but if I attach a 27v battery I blow the mosfet. I'm just a novice at electronics so can only use very basic maths but I'm wondering if I need to add protection the Gate of the Mosfet, or add an extra Mosfet as per dotted line?
    As I understand it the Mosfet will take 30A and accept up to 20v on the gate so not sure what I need to do to make this survive a 27v load.
    Load Dump circuit JPG.JPG Load Dump circuit JPG.JPG successfully
  2. Harald Kapp
    11,642
    2,690
    Welcome to our forum.
    At 10A, the "heat dump" resistors will develop a voltage of 0.7Ω*10A=7V. Therefore the rest of the voltage 21V (28V-7V) will drop across the transistor(s). This evaluates to a total power of 21V*10A=210W. The sihf22n60e is rated for max. 35W /datasheet) and is therefore heavily overloaded. You need to use multiple transistors (or a transistor rated for higher power dissipation) and a proper heatsink or, much simpler, use bigger load resistors e.g. 2.7Ohm - which then will will have to burn the excess power as heat.
    Andytester and KrisBlueNZ like this.
  3. Andytester
    Andytester
    10
    Aug 14, 2014
    Thanks Harald
    Your answer make sense, thanks for your help. I'll keep the original circuit for low voltage use and construct a new circuit using much bigger (1000w) FET's. I'll also add a bigger heatsink and some switchable load resistors. I should have a universal load for multiple jobs once its complete.
    Cheers
  4. (*steve*)
    25,497
    2,839
    Be sure to read the (not yet complete) resource dealing with heatsinks.
