battery charging temperature compensation
Discussion in 'Electronic Basics' started by kell, Oct 31, 2005.
  1. kell
    kell Guest
    Found a reference for lead acid; about -5.5 mV/*C per cell.
    Seeking the same info for li-ion.
    With lead acid you would get a 1% compensation differential with a 4.4
    degrees centigrade change. If li-ion batteries were to require
    compensation of the charging voltage versus temperature on the same
    order of magnitude, then that would take you outside the 1% voltage
    regulation specified for li-ion batteries even within a fairly narrow
    temperature window. But I can't find any information about this.
  2. PeteS
    PeteS Guest
    Li+ batteries, when charged using constant current/constant voltage (as
    specified by the manufacturer) require no temperature compensation in
    the charger when being charged within their acceptable temperatures.
    For Li+, charging should only start when 0C <= T(batt) <= 40C. Charging
    can continue for 0C <= T(batt) <= 45C. Li+ should not be charged
    outside these temperature limits (for safety reasons).
    Cheers
    PeteS
  3. kell
    kell Guest
    show me a link where I can look at that information.
  4. kell
    kell Guest
    It will take more than a blanket statement to convince me that
    temperature has no effect on the chemistry.
  5. PeteS
    PeteS Guest
    Grumpy today are we?
    Temperature *does* have an effect on the chemistry. read carefully what
    I actually said:
    << require no temperature compensation in the charger when being
    charged within their acceptable temperatures >>
    There's that note about acceptable temperature ranges. Indeed, it is
    because of chemistry changes that one should not charge the device
    outside the temperature range I stated. Unlike other chemistries where
    we can compensate a little for a wider temperature range, Li+ and
    LiPoly are not susceptible to this technique.
    As to manufacturer's documentation, they are a google search away.
    Try varta batteries (They are one of the many suppliers I use).
    http://www.varta-microbattery.com/en/oempages/index.htm
    You can also look for scholarly papers on the actual chemical effects
    within Li+ quite easily.
    Cheers
    PeteS
