Battery charging behavior.
Discussion in 'Electronic Design' started by Boki, May 24, 2007.
  1. Boki
    Boki Guest
    Hi All
    One of our wireless short range communication module, its charging
    behavior is:
    0~2.9V trickle charge. seems control by h/w
    3V~3.8V fast charge. should be initilized the fast charge by s/w.
    3.8V~4.2V trickle charge. must be controlled by s/w.
    Question, why need trickle charge at low voltage range.
    at 0~2.9V range, the charging LED will not turn on. Why need to turn
    off ?
    One more question, it seems after charging complete, there will be
    some current drawn, therefore the total voltage of battery will go
    down, when go down to a threshold it will recharging again.
    Any info I can study more ? thank you very much!
    Best regards,
    Boki.
  2. budgie
    budgie Guest
    If you are discussing Li-XX chemistry (the voltages sure sound that way) then
    the trickle below 3v is the standard way to bring the cell into the
    safe_to_charge_normally region. Current *has_to_be* very low when the cell is
    undervoltage, for safety reasons. Similar charge restraint is required when the
    cell is under-temperature.
    Depends how much current and where it is going.
    Again, if Li-XX then have a good read of the data sheet for a charge controller
    chip - such as the MAX1737.
    If not Lithium chemistry, ignore the above.
  3. Boki
    Boki Guest
    Yes, I am using Lithium battery, very useful, thanks!
    Boki.
