Battery charger with LM317
Luis Costa
Mar 13, 2015
30
Mar 13, 2015
30
Under the schematic supplied by the manufacurer its basically the same as the voltage divider yet with another resistor between the output terminal and R1. Does this much amps damage the battery? its like 0,2 ohms. I've been finding it hard to equate that, Can someone help? Ty
davenn
14,260
14,260
can you please show a circuit so we know what you are referring to :)
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
I suspect the resistor in question will be between the 317's output and the voltage divider used to set the output voltage.
If this is the case, then the function of the resistor is to limit the current available at the upper end of the voltage range.
You're almost certainly looking at a charger for a lead acid battery :)
cjdelphi
Oct 26, 2011
1,166
Oct 26, 2011
1,166
The lm317 can be operated in 2 modes...
Voltage regulation (voltage set from a resistor divider)
Current regulation which limits the output to a set current
Luis Costa
Mar 13, 2015
30
Mar 13, 2015
30
it has the battery charger mode right? divider with another resistor topping the divider to the output terminal.
https://encrypted-tbn2.gstatic.com/...lgLlKErxbu_4PRNWzNFRVtaTmPAxBGBTu3IenrS-slDQa
yeah i saw Z0=Rs(1+R2/R1)
gets a kinda low impedance but seems enough...
i was thinking 12 at 0.2 ohms giving a straight output current of 60 amps...then some connections got shorted in the pad and it heated intensely, Worked, 0,3/247/442 Ohms for a 3.7 accumulator.
