Battery - Charge or be Charged?
Discussion in 'Power Electronics' started by Kiggori, May 30, 2017.
  1. Kiggori
    Kiggori
    May 30, 2017
    Hey guys so i have a lithium ion battery and im wondering how i would set that up in a custom portable charger. Im looking to be able to use it to charge my phone which needs atleast 2.0A pumping through it. Tell me if you need more info and thanks in advance
  2. BobK
    7,682
    1,686
    My advice would be to get a commercial Lithium Ion battery charger. These batteries are tricky to charge and can catch fire or even explode if it is not done right, as Samsung learned recently.
  3. Audioguru
    Audioguru
    2,873
    644
    Sep 24, 2016
    You must learn about the dangers of charging and discharging a Lithium-Ion battery to avoid an explosion and/or very hot fire. Usually a charger IC is used that is programmed for the spec's of your battery. The IC has many safety features in it.
    The phone already has a charger circuit in it. It is powered by a 5V power supply and the battery cell that you will use must drive a boost converter to boost its voltage up to 5V. Your "custom portable charger" is commonly available as a Power Bank.
  4. BobK
    7,682
    1,686
    Which you can buy cheaper than you can make.
