Battery based DC motors
Discussion in 'Electronic Design' started by Donald, Feb 24, 2006.
  1. Donald
    Donald Guest
    I am looking into building a motor controlled lift.
    I need it to be portable.
    The motor I have in mind may draw 30 Amps under full load.
    I have read that a voltage boost regulator is a good thing to have
    between the battery and the motor.
    So, my question is:
    Where can I find a 12-14V in, 12V+ out at 30+ amps boost regulator??
    Build or buy is fine.
    donald
  2. Guest
    You've misunderstood what you read. Repost on sci.electronics.basics to
    find out how. Here, all I am obliged to do is to point that a voltage
    boost regulator wouldn't do anything useful in your application.
  3. James Beck
    James Beck Guest
    Really?
    Where did you read that?
    If your battery is properly rated for the load you shouldn't have a
    problem. I have seen thousands of lift gates out there hooked directly
    to a battery, lots of vehicle winches too.......
