Hey everyone i am new here.. and fairly new to electronics.. I have a few really basic questions..
1. Why does a rechargeable AA say 1.2 volt. But a 4 x AA,connected in series, charger is known as a 6 volt?
2. What will happen if you hook the 6 volt 100 ma charger , up to only 3 batteries in series? Will they over charge? Will it still work? will the batteries still work.. cuz i only need 3.6 volts... not 4.8
3. LED's : some led's say they are 3.6 volt, some 2.2 volt.. but i see some people hook them all up to the same line with no resistor... What happens to the 2.2 volt led when it is hooked up to the 3.6 line? suck more juice? shortne life of LED? ??
4. When calculating using OHMS law, for the supply voltage on 4 AA rechargables do i put 4.8 or 6 volts?
Thanks in advance..
Thanks in advance..
