Batteries in Series AND Parallel to get 2 Usable Voltages?
Discussion in 'Power Electronics' started by guido666, May 10, 2011.
  1. guido666
    guido666
    3
    May 10, 2011
    I have 3 battery packs that are 7.2V each. I need 7.2V to run one thing, and 21.6V to run a different thing. Can I hook the batteries up in series, for the 21.6V, and simultaneously hook them up in parallel for the 7.2V?
    Here is a crude drawing of what I'm asking...
  2. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
    Hi Guido
    I'm sorry man, that idea just won't work.
    You could just put them all in series and that would make your high voltage, and then you could draw your low voltage from the lowest battery in the stack.
    The problem is that the current for the high voltage would have to come from the same battery that is already providing the low voltage. So the low-voltage battery ends up doing double duty, running out first and making recharging difficult.
  3. guido666
    guido666
    3
    May 10, 2011
    Ok, can you clarify the reasons that it won't work? I want to make sure I understand this fully.
    Some rebuttals/questions...
    - Recharging is not a concern. I can remove the battery packs and recharge them individually.
    - So I can only draw the low voltage from one battery? Does it have to be the lowest voltage one?
    - I have seen other "parallel and series" configurations - how do they differ and work? (See attached.)
  4. poor mystic
    poor mystic
    1,074
    33
    Apr 8, 2011
    Well Guido I guess if you try connecting that cct up it'll soon show you there are problems, namely a short circuit around each battery.
    Take the right-hand battery for example. Follow the black wire up from the left-hand terminal, and see it change to a red wire. This colour change will not impress the electricity except maybe it'll get a good laugh.
    Follow the re-coloured wire down to the left-hand terminal of the middle battery. Notice a red wire leading off that terminal to the right-hand battery - the right terminal of the right-hand battery.
    The same is true of each battery in the circuit.
    So, each battery is short-circuited, and if you want to try connecting them that way I recommend heavy gloves and safety glasses.
    Time for some encouragement.
    Don't let this misconception stop you from learning about electricity or electronics. Nobody ever got good at seeing how circuits work without mistakes to make them blush and hide. Certainly not myself.
  5. guido666
    guido666
    3
    May 10, 2011
    Fantastic explanation. Now I completely understand. Thank you!
  6. wjousts
    wjousts
    17
    Apr 26, 2011
    They are only trying to get one voltage out of a set of 4 (presumably 12V) batteries. They show two different arrangements that achieve the same thing, getting 24V out with twice the capacity of a single battery.
    The first one "Larry's Method" takes two pairs of batteries in series (i.e. 24V) and connects them in parallel (i.e. double capacity). The second "Our Method" takes two pairs of batteries in parallel (i.e. double capacity) and connects them in series (i.e. 24V). Other than "less wires", I'm not sure if there is really any reason to prefer one over the other.
  7. osterchrisi
    osterchrisi
    28
    Mar 8, 2011
    I don't know if that is an option but why not simply hook up all the three batteries in series to get your high voltage and then put a voltage divider after it (best with an opamp) to get your low voltage...?
  8. (*steve*)
    25,501
    2,841
    That's fine if alll you want is a voltage, but if you intend to draw current from it then it won't work.
    At it's best it will be highly inefficient and be no better than having a single 7.2V battery.
  9. nbw
    nbw
    48
    May 8, 2011
    Maybe the 3 cells in series for the higher voltage, with a step-down for 7.2V? As with anything in electronics though - there are no free lunches - and it's not the most efficient way of doing things. You might get 70-80% efficiency on the step-down, maybe up to 90% on a good day - but that's introducing an element of complexity you probably don't need on your plate at present.
