James Meyer
Occam would agree...
Occam might agree, but only if he never read the whole thread.
Jim
Occam should have grown a beard - much simpler.James Meyer said:Occam might agree, but only if he never read the whole thread.
Jim
JS2 said:About ten lines of code in C or C++; not at all hard to add.
-JS2
Sneaky scales fudge weights deliberately.
I suspect that many modern, microprocessor -controlled bathroom scales
have programmed in hysteresis to increase user confidence in the
scale's accuracy. The scale remembers fresh measurements, say 166.2#,
and if it next measures same weight +/- a little (within a short time),
say 166.8#, then the scale decides to report the *original* measurement
166.2#. Neat. Sneaky. User believes the scale is highly repeatable.
On such a scale, I weigh myself multiple times and get the same reading
(to the 0.2#) each time. 166.2#, 166.2#, 166.2#, 166.2#, ...
Then I weigh something different (myself holding a load), to reset the
memory.
Then I weigh myself again... Now, get something like 166.8#, 166.8#,
166.8#, 166.8#, ... very solid again, but 0.6# different from 1st
series of measurements.
I tried 6 models (2 or 3 brands) at a retail store display and find
this "feature" common.
Is it important? Maybe yes in the following scenario -- in some sports
like wrestling, boxing, judo, you have multiple competitors weighing in
at the same time, same scale, with possibly very similar weight. Some
competitors are concerned with as little as 0.25#. In this case it
seems one competitor could inherit the weight measurement of the person
in front of him.
In a perfect world, competition weigh-in equipment should be
certified/calibrated. But since the bathroom scale appears so
repeatable, some competitions now use modern, microprocessor
-controlled bathroom scales.
Somebody's going to say... "you shouldn't do that". Right, I agree.
But (a) it's happening, because (b) this hysteresis (memory)phenomenon
isn't widely known, I suspect.
Anyone care to confirm? Contradict? Repeat the experiment on their
own scale? Comment? In my experiment I didn't bother to determine
what weight difference resets the memory -- 1#? 1.5#?
Regards,
John Ruckstuhl
The Real Andy said:Having spent some time in the weiging industry, i can assure you that
the cheap portable bathroom scales that you buy are neither:
a. repeatable
b. accurate
c. linear
In fact, most will become more innacurate in the most common weight
ranges.
In AU, a cheap set is $20, a good repeatable set is $400. The
expensive scale can be recalibrate and remains linear. Should it not
be linear a multi-point cal can be done. The cheap set can only be
thrown.
Most cheap sets are innacurate of the shelf as they are made in china
and fail to take into account local gravitational constants
Thanks to all who took time to reply.
Yesterday I went to a Bed, Bath, & Beyond store where there were
several models on display.
I brought with me several 0.5 liter water bottles (approx 1 lb.) and
half-consumed one (approx 0.5 lb.) so that I could adjust my weight in
0.5 lb. increments. I tried 3 models and found two that I think
exhibited this programmed hysteresis, and one that did not.
The $40 Thinner TH300 uses load cells and reports to 0.5 lb.
Holding an empty shopping basket and full pockets, I measured at 181.0
six times in a row. Then, holding ~0.5# in my basket, I still measured
181.0. Again, holding ~1#, I still measured 181.0. Then, when holding
~1.5#, apparently past the programmed hysteresis threshold, scale
reported 182.5.
The $50 Tanita BF679 reports to 0.2 lb. It did not have hysteresis.
Each measurement was independent, reporting like 178.2, 178.4, 178.6,
178.4, ... (I wasn't holding an empty shopping basket for this one).
The $60 WeightWatcher WW60 (Scales by Conair) uses load cells and
reports to 0.1 lb.
I (plus basket) measured 180.7 six times in a row. Then holding ~0.5
lb., I measured 180.7 again. Then, holding ~1#, I measured 181.9 .
So, I see this programmed hysteresis in some models, with a breakaway
delta of ~1#.
I had thought I originally noticed this two months ago in several
Taylor models and a Tanita, but I wasn't able to test any Taylors
yesterday and my one Tanita test didn't show it.
Best regards,
John Ruckstuhl
Do you have any experience with the newer digital models? Not the low-end
ones, but ones like the Tanita with ostensible 0.2 lb resolution, priced
around $50-90 (US).
For instance, http://tinyurl.com/49swe, or the more expensive German-made
Soehnle brand http://tinyurl.com/3t6kt.
GG
I suspect that many modern, microprocessor -controlled bathroom scales>
There's no such thing you jerkoff.
Ken said:The "digital" bathroom scales I've disemboweled only digitized the rotation
of a disk. The disk would have had numbers on it, if it were a
"mechanical" scale. The disks had black and transparent radial bands, that
were read by a quadrature decoder/counter, and displayed on 3 LED digits.
The mechanics were exactly the same as in the old bathroom scales we've had
for a nearly a century.
Chris said:Do you think that this behaviour would result if the ADC resolution is
coarser than the display resolution, for example the LSB represents 1.5#?
Or maybe the ADC has missing codes. This wouldn't require tricky
programming, just a bad ADC.
JS2 said:I've noticed with balance scales that the weight shifts by several pounds
depending upon where you stand on it ... I assume you're supposed
to stand more or less in the center, an inch one way or another can
make a difference of a pound or two (important if you're doing a
sport with weight divisions).
delta of ~1#.
