Hi, I want to know basic use of ferrite bead. also the use of crystal. Thanks&Regards Joshua
J joshua Jan 1, 1970 0 Feb 21, 2006 #1 Hi, I want to know basic use of ferrite bead. also the use of crystal. Thanks&Regards Joshua
P Pooh Bear Jan 1, 1970 0 Feb 21, 2006 #2 joshua said: Hi, I want to know basic use of ferrite bead. also the use of crystal. Click to expand... Is there anything you *don't* need explaining to you ? Graham
C [email protected] Jan 1, 1970 0 Feb 21, 2006 #4 joshua said: Hi, I want to know basic use of ferrite bead. also the use of crystal. Thanks&Regards Joshua Click to expand... Crystals are used in some cults to summon up the spirits, you can make a dainty neclace with ferrite beads.
C [email protected] Jan 1, 1970 0 Feb 21, 2006 #5 joshua said: Hi, I want to know basic use of ferrite bead. also the use of crystal. Thanks&Regards Joshua Click to expand... Crystals are used in some cults to summon up the spirits, you can make a dainty neclace with ferrite beads.
P Paul Burke Jan 1, 1970 0 Feb 21, 2006 #6 joshua said: Hi, I want to know basic use of ferrite bead. also the use of crystal. Click to expand... The ferrite bead is stuffed up the are of the lazy bastard who can't be bothered to google for himself. The bigger the better. The crystal is formed into a ball, and gazed into to find Google so you can do your own "research". Paul Burke
J John Popelish Jan 1, 1970 0 Feb 21, 2006 #7 joshua said: Hi, I want to know basic use of ferrite bead. also the use of crystal. Thanks&Regards Joshua Click to expand... Please start a new thread for each on the electronics basics group. Thank you.
R Rich Grise Jan 1, 1970 0 Feb 21, 2006 #8 if u know means briefly explain me. Click to expand... http://folk.ntnu.no/shane/stasj/pics/humor/div/128.html http://www.google.com/search?q="ferrite bead" Have Fun! Rich
R Richard Henry Jan 1, 1970 0 Feb 21, 2006 #9 joshua said: Hi, I want to know basic use of ferrite bead. also the use of crystal. Thanks&Regards Joshua Click to expand... Crystal makes oscillations. Ferrite bead stops them.
F Fred Bartoli Jan 1, 1970 0 Feb 21, 2006 #10 Richard Henry said: Crystal makes oscillations. Yup. Ferrite bead stops them. Click to expand... I thought it was transistors.
