Basic rechargeable batteries question
N
Ninad Tipnis
I would like to why AAA/AA/C/D rechargeable batteries have 1.2V nominal
voltage? and not 1.5V as the case for alkaline batteries.
Ninad Tipnis
D
Donald
Ninad said:
Ninad Tipnis
chemistry
M
martin griffith
Ninad Tipnis
Phlogiston
martin
Ninad said:
Ninad Tipnis
Because you touch yourself at night.
P
Peter Bennett
Ninad Tipnis
The voltage of any battery (rechargeable or disposable) depends on the
chemical reactions that occur within the battery.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Rechargeable batteries generate electricity by a different chemical
reaction than that used in alkaline batteries
http://www.answers.com/topic/rechargeable-battery
and that is why the nominal voltages are different. If you searched on
chemical thermodynamics and Gibbs free energy you might find a more
detailed explanation - I studied it in my second year at university
(1961) and retain very little of it.
P
Phil Allison
"Ninad Tipnis"
** Because that is what the chemical reaction inside generates.
Batteries are products of chemical engineering - not the efforts of
electronics designers - they can only do what the laws of chemistry allow.
A good performing, rechargeable cell that generated a steady 1.5 volts would
be sensation in the battery market place.
Luckily, the 1.2 volt NiMH ones we have now are very useable in most
devices originally intended to use non rechargeables. This is because that
1.2 volts of output is quite steady during discharge - unlike alkalines etc
that constantly lose output voltage as they go - right down to 0.8 volts
before they are exhausted.
........ Phil
D
default
Ninad Tipnis
The battery chemistry determines the voltage. Change plate material
and you change the voltage out for a given electrolyte.
1.2 volts will almost always work in place of 1.5 volt primary cells -
the battery keeps putting out 1.2 volts for most/all of its life -
unlike 1.5 volt alkaline or zinc carbon batteries which droop from the
time you start drawing power.
H
Homer J Simpson
It's because of a plot by the Great Satan.
M
Michael A. Terrell
Ninad said:
This is not a design question. It belongs on
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
P
Paul E. Schoen
Ninad Tipnis said:
It's a 20% penalty levied by the Bush administration to discourage
renewable energy!
Al Gore
D
D from BC
nominal
Ninad Tipnis
Wish I really knew.. I'm still stuck on why a nail and a penny
stuck in a lemon produces electricity.
Apparently 4 lemon batteries lights an LED!
As an hobbyist/designer I just see 1.5V and 1.2V and other
specs...I try to stay in the electronics domain and avoid
chemistry.
Besides, I didn't do so well in chemistry and it's messed up my
electronics work sometimes. So I recommend learning chemistry
...And physics,..and math and ...Damn it! It's endless!! I'm
warning you...Do you really want an answer to that battery
question because once you're down that rabbit hole.... there's
no getting out. :)
D
Sorry...after seeing some of the funny replies to this thread I
had to add.
jasen
different chemicals => different voltage
the word for today is "electronegativity"
Bye.
Jasen
