Hello everyone!
I am struggling to understand how you use a transistor to switch a circuit on or off. The reason that this came up is that I have this infrared detector and emitter pair and when the detector senses IR it will drop the voltage. I was just playing around and wanted to use this info. to swtich a circuit on and off with an NPN transistor. I couldn't get it to work Could someone here, in very simple terms (still a noob here!) explain how you get a transistor to switch something on/off?
I do know that you have to have a voltage difference of so much between emitter and base for it to allow current to go through to the collector in an NPN.
Any help is appreciated. Thanks guys!!
Noura
Noura
