basic logic question
newbiet
Jul 28, 2011
Jul 28, 2011
am new to digital electronics and am wondering why the logic for the output of a OR gate is equivalent to a + sign when evaluating an expression..
for example if i was drawing the circuit for the following experession F=A + B...I would use an OR gate with A and B as inputs and F as the output. Yet the truth table for an OR gate is different to that of a Sum output when using a Half Adder to add bits A and B..don't under stand this..
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
+ is just used as a notation, it does not mean addition.
poor mystic
Apr 8, 2011
1,074
Apr 8, 2011
1,074
Hi newbiet :)
'OR' is not equivalent to 'plus' in any way - it is just that convention uses the same symbol for 2 quite different concepts, which can be very confusing.
newbiet
Jul 28, 2011
Jul 28, 2011
notation
So using a + for an OR gate is just poor notation.
Using a '.' for an AND makes sense though.......!?:D
daddles
Jun 10, 2011
443
Jun 10, 2011
443
No, it's perfectly acceptable notation and was likely invented long before any of us were alive. In programming, this is called operator overloading because there are many more operations than there are symbols on the keyboard (I exclude Unicode). You can see that it would be very clumsy to e.g. have to use a different symbol for matrix addition than to just use the + symbol. Yet adding numbers and adding matrices or vectors are completely different concepts -- and the problem becomes worse as you go into more abstract things in mathematics. Thus, it's important for an expositor to list his/her symbols and notation. However, for elementary things like Boolean algebra, it's not usually done because most folks know the details. Now you know too. :)
daddles
Jun 10, 2011
443
Jun 10, 2011
443
It's in Boole's "An investigation of the laws of thought" published in 1854.
poor mystic
Apr 8, 2011
1,074
Apr 8, 2011
1,074
Wowee. Does Boole actually use that notation? I had assumed it was all conjunct this and disjunct that.
Oh well St Claude didn't invent everything. I guess.
daddles
Jun 10, 2011
443
Jun 10, 2011
443
Well, his most important invention was the Dirt Claude. And his first-name namesake grandfather on his mother's side (nee Balls) wrote a book called "Tiger's Revenge".
poor mystic
Apr 8, 2011
1,074
Apr 8, 2011
1,074
daddles will have his little joke. :)
after a while, if we are... lucky! he will explain it.
poor mystic
Apr 8, 2011
1,074
Apr 8, 2011
1,074
If you like being confused btw i can help!
The following functions convert numbers for use in logical operations:
XOR(a,b) = (1/2)*((-1)^(a+b)+1)
AND(a,b) = (1/2)*((-1)^(ab)+1)
These functions imply a kind of logic in which XOR and not OR is a fundamental operation.
Also as you have pointed out addition and multiplication have their application as logical functions.
Best stick with Boole until after the exam.
(*steve*)
25,510
25,510
daddles will have his little joke. :).
I have a feeling they may be what my wife refers to a "Dad Jokes".
Just be thankful I'm not posting any (he says, hoping nobody spots the one he posted earlier...)
