Basic LED Wiring
Discussion in 'LEDs and Optoelectronics' started by Zersh, Jul 1, 2010.
  1. Zersh
    Zersh
    Jul 1, 2010
    So I'm new at this.
    I'm trying to wire up some LEDs to a battery pack and a switch. To connect the LEDs to the wires, is it better to bend the terminals of the LEDs to give the wires better grip or should i just e-tape the whole shebang together?
    Thanks for help!
  2. (*steve*)
    25,482
    2,830
    One word... solder.
    Also have a look at solderless breadboards which allow you to make up circuits without soldering anything.
    Be aware that a resistor, or some method of current limiting, is required when you use LEDs. The alternative is that they have a very brilliant, but very short life.
  3. eem2am
    eem2am
    414
    Aug 3, 2009
    yes , LED s need "current controllers" , so you need to take the necessary precautions if u sing a battery...which is a voltage source.
